Samsung printer won't print and roller i=does not run
SOURCE: Can I print in Dos Programme with USB Printer
Assuming the printer can understand DOS coded printouts (which most should be able to), you can do it like this: Go to Control Panel | Printers | ML 2010 and share the printer. Then go to a command prompt Start | Run | type cmd Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type NET USE LPT2: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES at a command prompt. Now you can print to LPT2: and the output will go to the USB-connected printer. To find your computer name, right click on the My Computer icon (either on your desktop or the start menu) and choose properties. The window that opens will have a Computer Name tab.
Posted on Aug 28, 2007
SOURCE: laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Posted on Feb 03, 2009
SOURCE: Samsung ml 1640 after refill
http://www.fixyourownprinter.com/forums/printer/59558
Posted on Mar 01, 2009
SOURCE: Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Posted on Mar 02, 2009
Sep 21, 2014 | Samsung ML-2010 Laser Printer Monochrome...
May 17, 2010 | Samsung ML 2010 Laser Printer
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Jan 01, 2010 | Samsung ML 2010 Laser Printer
Jul 14, 2009 | Samsung ML 2010 Laser Printer
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Mar 17, 2009 | Samsung ML 2010 Laser Printer
Mar 01, 2009 | Office Equipment & Supplies
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Dec 23, 2008 | Samsung ML 2010 Laser Printer
54 people viewed this question
