Question about Smith Corona Wordsmith 100 Typewriter
Spacebar is not working properly on Smith Corona SC110 typewriter
I am having an issue with my Smith Corona SC110 typewriter. My spacebar is not spacing between words. How can I fix this?
Mitch Vass
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Space bar key switch is stuck or bad, or needs cleaned
Posted on Jul 02, 2016
5 Related Answers
Anonymous
  • 183 Answers
SOURCE: SMITH CORONA KA 13 WORD SMITH
For a manual, try Google. Just put in "Smith Corona KA 13 WORD SMITH MANUAL'. If you can't find one there, then you are prabably out of luck. To change the margin simply go to the left margin, use the "backspace" or spacebar to position the print head where you want the margin set and then push the L MAR key. To change the right margin use the same procedure and hit the R MAR key.
Posted on Oct 24, 2008
bernieq
  • 6 Answers
SOURCE: I need a user manual for smith corona SD 680 Word processing
http://www.manualfox.com/
Posted on Dec 11, 2008
male_28_cam
Aruna Singh
  • 1555 Answers
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
Posted on Jun 21, 2009
Anonymous
  • 5 Answers
SOURCE: Smith Corona SD 250
1) Move the print carrier to the center of the platen using the SPACE and back arrow.
2) You will see a lever on the right side of the carrier. Pull this lever toward you and
lift out the daisy wheel.
3) Place the daisy wheel into the slot with the characters facing the platen.
4) Push the lever back into position.
5) Press the CODE and = (SETTING) key.
See the user's manual here:
http://www.smithcorona.com/pdf/WS200Man.pdf
Posted on Aug 01, 2009
Anonymous
  • 20 Answers
SOURCE: My typewriter, an Electra 120 smith-corona, is
This is an old mechanical typewriter, rather than electronic. Thus, the sticky keys are gummed up and quite possibly the rails are gummy as well. Look in your phone book under typewriters. My company to this day has a full-time typewriter repair person, and there should be many such companies out there. Should cost about $75 to repair.
Posted on Oct 23, 2009
Why am I unable to space between words?
no code, bad space bar, key swithch, or need the switch cleaned.
Aug 18, 2014 | Smith Corona Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Oct 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Smith Corona Wordsmith 100 Typewriter Logo
375 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
