Additional function is not working it is very big problem 4 me
Check additional function switch and replace additional function switch
Testimonial: "but how can i check it"
open the control panel and compare the additional button with other if button is not damage clean the dust if button is damage replace button by solder
how to open the control pannel
before damage it is working very tight but now after very tight pressing itis not working
thanksalot brother for support u r 2 good keep it up
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
