Question about Amerock Hardware & Accessories
Adjusting upvc door hinges - Amerock Hardware & Accessories
Planning to purchase Fenesta UPVC Windows, need reviews?
I just renovate my house in last year and use designer doors and windows from Fenesta for giving an attractive look to my house. After using designer windows and doors my house looks prettier than ever. Even my friends also appreciate my selection and they like them. I just want to say my heartiest thanks to Fenesta who are having such a wonderful and unique designer doors and windows.
Fenesta UPVC Windows and UPVC Doors
Jul 31, 2014 | Home
What benefits UPVC doors and windows can add to my home?
uPVC Doors and Windows are luxurious design product that are created with consideration on evocativeness and functionality. These are energy-saving and soundproof that provides better quality of life. As you mentioned that you are going to buy them, just check out with LG Hausys India. Refer given link.
May 30, 2014 | Building Materials
Are the UPVC sliding doors and windows good for houses?
I am using Fenesta UPVC sliding doors and windows. It's very good to use and long lasting. If you use wood or aluminum doors and windows then you need much maintenance which is irritating but, with UPVC you will never face this problem. I will recommend you Fenesta sliding doors.
Dec 18, 2013 | PLATINUM PRODUCTS upvc50...
Which one is best between UPVC and Aluminium Doors & Windows?
http://www.adwin.net.in/f3f667da-9aa9-44f0-977f-fd9314b10b96.png
uPVC WINDOWS SYSTEMS
Adwin uPVC Windows System: Relief with the Elegant Window Style.
Adwin offers the wide range of uPVC Windows system, compatible to a variety of architectural designs. Adwin offers below windows system to transform your home today with the fervor feeling of rest.
•Casement Windows
This is a classic style that never goes out of fashion. The window panels open outwards or inwards, from the sides, giving the widest feel of openness.
•Sliding Windows
Perfect for areas where opening space is restricted or window sizes are large. Rather than restricting the view using multiple casement panels, we recommend using large sliding panels that give the feeling of expanse.
•Villa Windows
Recommended for ground-level windows which may require additional security. The grills are sandwiched between two frames, making their removal impossible. Our profile’s elegance and fine finish add to its value.
•Top Hung Windows
Ideal for areas where privacy is of prime concern, yet ventilation is required. They are generally used at the ceiling level or in places where view needs to be blocked without restricting the flow of air.
•Tilt & Turn Windows
T & T gives you the option to control your environment with precision. It is essentially 3 window types in one: fixed window, casement window, and top hung window. The tilt function allows for top ventilation, easily enabling hot air to quickly escape through the top portion of the window. This also cuts back on allowing strong breezes into the room. The turn function, however, creates ample airflow and movement for maximum ventilation.
If you are looking for the best uPVC windows system, ADWIN is the registered brand of ADVANCED WINDOWS & DOOR SYSTEMS, a company with 15 years' lineage in the Indian infrastructure industry. Adwin is the best choice for you. Visit Today - http://www.adwin.net.in/upvc-window.html
Dec 05, 2013 | Scotch 600 Film Tape,upvc,clear,3/4 In. X...
Where can I purchase quality UPVC windows and doors in Bangalore?
Fenesta Building Systems is India's largest windows and doors company. It has installed more than a Million windows doors across nearly 150,000 homes. This will be best for you to purchase UPVC windows or doors in Bangalore. To find your nearest dealer visit: http://www.fenesta.com/dealer/upvc-windows-doors-bengaluru.aspx
Which Door is best UPVC doors or wooden Doors ?
Wooden doors need maintenance regularly because they have poor insulation & also a poor conductor of heat. Other than UPVC windows are more environmentally friendly with elegant looks. UPVC windows and doors use international quality hardware that allows ease of use. So I think UPVC windows & doors are better than wooden doors. If you want to know more difference visit here http://www.fenesta.com/wood-windows-doors.aspx
Nov 28, 2013 | Cars & Trucks
Are UPVC sliding doors and windows are best to use in home?
Yes, UPVC sliding doors and windows are good to use in home. Its very gud to use and long lasting.The UPVC products doesn't require painting for long usage, they are poor conductors of heat, UV resistant, not prone to termites etc.
So, I would like to suggest you that you should use UPVC products instead of aluminium and wooden products. For more information you can directly check http://www.lghausys.com/in/product/windows/windows-doors-indian-style.jsp
Oct 26, 2013 | Cars & Trucks
We have upvc french doors, 1 seems 2 have dropped and is catching at the bottom is there any simple way to adjust this?
yes if you have an hinge which looks like small flag there are 3 ajustment places on these you need the one pointing towards glass on tip of flag normally small white cap on front take off and use allen key and it wind back towards wall taking off the drop to it if not flag hinge you will have to call engineer ok hope this helps bub
Jun 29, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Hardware & Accessories Logo
65 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
