With tool unplugged rotate tool end with your finger tips if it gives any resistance to this your bearings have forign material in them (happens if your doing grinding allot) if a liberal dose of light oil (sewing machine) does not improve this friction im sorry but you;ll have to replace tool to run slower speeds
SOURCE: Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
SOURCE: The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
SOURCE: Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
SOURCE: worn front bearing on Dremel Multipro
Sorry, here is a link to that picture, full sized.
Grease Monkey 626
SOURCE: How do i take the bit off of a dremel multipro
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
