Question about Lexmark X Office Equipment & Supplies
How to fix a #1203 error message on lexmark printer x5495
How do you fix #1203 code on lexmark printer x5495
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
Ekse
  • 13434 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
Anonymous
  • 1049 Answers
SOURCE: Lexmark x3350 cartridge error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Posted on Jul 28, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: HOW TO REFILL LEXMARK X5495 PRINTER
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 04, 2008
Anonymous
  • 435 Answers
SOURCE: error 1203 Lexmark F4270
The 1203 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
click here for instructions).
Posted on Feb 14, 2009
What is error #1203 and how can it be fixed
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X5495 Printer
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Comes up with erroe # 1203... what is that?????????????????
The error indicates either a communication failure between one of the cartridges and the printer or a short in one of the cartridges. To determine which is causing the problem, follow the troubleshooting steps on this link: http://bit.ly/aDUAjM. Thanks.
Aug 20, 2010 | Lexmark X5495 Printer
Can't find my manual encountering an error 1203, do you know what this means?
The error indicates there is a communication failure between the cartridges/one of the cartridges and the printer or a short in one of the printheads. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/8YrwYY. This should guide you on what to do. Thanks.
Jul 30, 2010 | Lexmark X5495 Printer
ERROR 1203
This error is to do with the ink
Please see http://www.fixyourownprinter.com/forums/inkjet/30183
Apr 27, 2010 | Lexmark X5495 Printer
My lexmark printer x5495 has error 1203 what doi do?
You can only try this it may workError 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aug 13, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
264 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
