RCA D52W23 52" HDTV CRT TV Logo
Question about RCA D52W23 52" HDTV CRT TV
My tv keep cutting on then off and squellun - RCA D52W23 52" HDTV CRT TV
Posted by Nakeesha Johnson on
Why does my TV screen keep cutting out
do you lose the audio signal when this happens ?
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Sound keeps cutting off
Bad smd audio output ic. Are hard to replace, may just need to replace main board.
4helpful
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Why do my tv keep cutting off by itself?
check your tv if the timer is on..if the timer is on,off it..
1helpful
4answers
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
2answers
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
