The instruction manual from the HP site will show you how to check the ink levels. But first you need to have the HP Printer software installed on your PC.
http://h10032.www1.hp.com/ctg/Manual/c03333598.pdf
You can download and install the driver from this site. The instructions on how to install will be there once you select the Operating system (Windows, etc) of your PC.
HP Deskjet 2510 All in One Printer Drivers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink!
Thank you.......
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
SOURCE: I want to check ink levels
To check the ink levels ofyour printer click on the start button of te computer and then click on control panel now go to printers and faxes open it and look for the name of your printer right click on the icon and go to properties now click on printing preferences and then go to the features tab in the features tab look for the printer service tab now go to the estimated ink level tab and see the ink level
SOURCE: How do I reset the ink levels on a HP Deskjet
First try the information below
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
