Why does my epson Stylus BX320FW not print
I have changed the ink cartridges but when I press print it just prints out a blank page
303 Electronics
  • Office Equip... Master
  • 345 Answers
If it is just a blank page when you are trying to print a color page, you may have all ink nozzles dry on the printhead. Print a nozzle test and it will show which colors are working. If the nozzle test is blank, you need to clean the printhead manually. See video for instructions:
Posted on Aug 23, 2019
wa2yyx
    Sergeant:
    Champion:
  • 282 Answers
Some older printers are no longer supported by windows vista, or XP
My friend had the exact problem and had to buy a new printer. It worked fine.
There may also be another problem. Go into control panel then printers and see if it is your default printer. if not then make it your default printer. Something else that you may want to try. If you have the CD that originally came with your printer then try using it to install the software in again. It may have been corrupted. If not then go here and find the drivers for your printer then download them and run them.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-IE&data=FCFfEfoyEiGXXpkffrkefK1QTrmSA3FMgVNxXJWcT20U003D&tc=6
Hopefully one of these solutions will help you out.
Posted on Aug 17, 2014
5 Related Answers
Basti
Edgar Allan Pagayona
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: Epson Stylus C45 not printing
common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Posted on Feb 08, 2009
Anonymous
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
Anonymous
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
Anonymous
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
HP OfficeJet 5610 leaves large blank areas
can be a problem on the thermal roller, have you try to clean print head first..?
Aug 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer window displays in foreign language. need english. pages come out blank.
  1. From the main menu, use the left and right Arrow buttons to scroll to Setup.
  2. Press the Select button .
  3. Press the right Arrow button until the heading you want appears on the display, and then press the Select button .
  4. Use the left and right Arrow buttons to scroll through the available menu items.
  5. When the setting (language) you want appears on the display, press the Select button to save the setting or enter the submenu.
  6. For Blank printout:Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge.
Clean the cartridges:
To clean the ink cartridges from the operator panel:
  1. Load plain paper. .
  2. From the main menu, use the left and right Arrow buttons to scroll to Maintenance.
  3. Press the Select button .
  4. Use the left and right Arrow buttons to scroll to Clean Cartridges.
  5. Press the Select button .
The cleaning page prints. You may discard the cleaning page when printing is complete.
To clean the ink cartridge nozzles:
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Clean Print Cartridges.
  1. If the print quality has not improved, click Clean Again.
  2. Print your document again to verify the improved print quality.
If you are still not satisfied with the print quality, wipe the ink cartridge nozzles, and then print your document again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Dell 946 All-In-One InkJet Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
After changing black ink it does print badly
remove and re-seat it.
calibration is automatic.
To print a test page try.
Press and hold the OK button.
Then press the left arrow key one time.
Release the OK button.
Printer tool box, use head cleaner, nozzle check.etc...
Replace the cartridge.
Hope this helps
Ric.
Apr 17, 2009 | HP Photosmart D5160 InkJet Printer
CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Mar 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printing blank pages
My printer has funn ink cartridges and it is printing blank pages and it is saying that the ink is empty. Please help
Feb 27, 2007 | Brother MFC 4420C All-In-One InkJet...
80 people viewed this question
jasbo
jasbo
Marvin
Marvin
