Question about Samsung LE Televison & Video
How to repair
Power turns on but no picture only a blue screen
Posted by Ruben Rios on
Everything powers up but screen does not turn on
try to hook up to external monitor. if it works your screen is bad. If not it could be your GPU. cost of repair from us would be like 70-140 to repair including return shipping.
Nov 19, 2013 | HP Pavilion dv4000 Notebook
Screen isn't blue when you turn on its white
The most common cause of white screen and no picture problems on this unit is a failure of the power supply board. Here is a repair guide with full dis-assembly and repair instructions that should be able to get you back going again. This guide is for the Visco TVs but the boards are the same as the Polaroid model
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 25, 2011 | Polaroid FLM-323B Television
What does it mean when the picture goes blue? the picture turns blue while we watching it
Typically it is an indication that the blue CRT is failing. If screen turned red, then the red CRT would be failing, etc..
Sometimes you might see the screen flash blue and then go solid blue, then shutdown.
You need an experienced repair person to fix it. It can be expensive.
Mar 20, 2011 | Sony KP-57WS500 57" Rear Projection...
TV was working fine till Friday 29 Jan 11. Went to turn it on screen was dark blue,but sound was on, after about 10min the screen went to bright blue then the picture came on. Saturday the same thing,...
The problem you are having is the power supply in the TV is failing. When you try to power the unit on you get on power or a slow turn on. It also can explain the problem of not running at full 1080p resolution because the higher the resolution the no power is required to operate the TV. Check out the article that explains the problem and how to repair it.
I hope this helps, if so please rate our solution.
BuddyMc
Jan 30, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Mitsubishi 55" MODEL WS 55513 1080 HDTV blue screen
I plugged my Dell desk top in and the XP screen comes up, but when windows comes on I getablue screen. Any ideas?
[email protected]
Jan 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My Sony KP-53S35 turns on, shows a blue screen, turns off
It sounds like the blue CRT (picture tube) is failing. The part number for this is 8-733-575-25 but you will need a technician to replace it for you as there is mechanical and electrical alignment to with with it. At that point it probably isn't cost effective to repair the TV. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Sony KP-53S35 53" Rear Projection...
Kp-fs57 blue screen then turns off
Could be one of three things the yokes, the flyback transformer or the picture tubes, all will be a costly repair. If it was mine I would invest the money in a new one.
Sep 09, 2009 | Sony KP-51HW40 51" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
214 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
