Kitchen Appliances - Others Logo
A
Anonymous Posted on Aug 17, 2014
Why won't my gold medal 2404 popper not pop the popcorn/
All it does is just burn the kernels and will not pop the popcorn at all.
Thomas Beaver
Level 3:
  • Master 2,119 Answers
  • Posted on Aug 17, 2014
Thomas Beaver
Master
Level 3:
Answers
2119
Questions
0
Helped
752082
Points
6319
Is the popcorn fresh. If popcorn is allowed to dry out too much it will not pop.
Rejuvenating popcorn that won pop
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
753216
Points
4266
Did you add a little bit of oil
4 Related Answers
Anonymous
  • 109 Answers
  • Posted on Mar 29, 2009
SOURCE: How much oil and popcorn kernels to use in gold medal machine
Try one ounce of oil, 1/2 teaspoon popcorn salt and 1/2 cup of popcorn and see how much it fills your machine and adjust quantities from there. This will usually fill a wok size bowl.
Darren Hanson
  • Posted on Oct 09, 2010
SOURCE: Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Anonymous
  • 1998 Answers
  • Posted on Dec 21, 2010
SOURCE: Gold Medal Products Whiz Bang
Have you checked to assure that the warmer switch and the kettle heat switch are both functioning properly? Also the timer on the bucket seasoning pump control box determines the length of time the heat element of the bucket pump is at HIGH HEAT i also suggest you take a look at this pdf of the manual of your machine under the troubleshooting guide area if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
http://lib.store.yahoo.net/lib/yhst-81132447584496/47699.pdf
BrianaWalker
  • 14 Answers
  • Posted on Apr 08, 2013
SOURCE: Gold Medal 2086 popper electrical
This popper can be used with any of the Gold Medal 2659 carts but requires the use of spacer 49677, which are not included an must be purchased seperately.
I am getting a very poor yield from one of the kettles despite the elements and thermocouples been fine. any ideas
The elements could be loose if element clamps are not tight or missing. check Check the amp draw on both the red and black and compare it to the other side. that will tell you if the wattage is equal. If it is and the elements are tight check the circuit board. The circuit boards on Gold Medal poppers are also ajustable for the over shoot temp and kettle dump temp. check the setting with the faster kettle.
Our store owns a gold medal #2656 popcorn popper but now it will not pop but few kernels. is it not getting hot enough or is it something else?
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
When I turn on the heat for the kettle to warm up. the breaker kicks.
It's shorting out somewhere. One likely area is the heating element inside the kettle.
We need operator's manual for Gold Medal Astro-Pop model 2012
Gold Medal Model number 2012 is for a 28x48 4 wheel cart only, it is not a popcorn machine.
Astro Pops are model 2010, have been for 30+ years.
Their Manuals are not publicly available because they have changed many, many times and the odds of you getting the correct one is slim.
What parts are you looking for? and what is the manufacture date of the machine?, the serial plate is in the lower right hand corner of the cabinet, behind the cart doors if there are doors.
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
47helpful
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
2helpful
3answers
1helpful
Galaxy popper g12 unpopped kernels
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
5helpful
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
