As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Method 1
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
[Type Y in response to this message.]
Enter Load Identifier:
[This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
Enter OS Load options:
[Leave this field blank, and then press ENTER].
After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 2
If you have a black screen with a messages like those :
>Windows could not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM
>Windows NT could not start because the below file is missing or corrupt:
X:\WINNT\System32\Ntoskrnl.exe
X:\WINNT\System32\HAL.dll
>NTLDR is Missing
Press any key to restart
>Invalid boot.ini
Repair with XP CD :
1. Boot with CDROM
2. Enter the installer XP CD
3. Press R if like this :
4. Press 1(or the other that show the installation drive) and enter the admin ]
5. Type Like This :
> C: CD ..
> C: ATTRIB -H C:boot.ini
> C: ATTRIB -S C:boot.ini
> C: ATTRIB -R C:boot.ini
> C: del boot.ini
> C: BOOTCFG /Rebuild
6. After Rebuild finish type this:
C: CHKDSK /R /F kemudian
C: FIXBOOT
"Sure you want to write a new bootsector to the partition C: ?" press "Y"
C: EXIT
Enter
