Question about Freezers
Looking for specs (cubes) on chest freezer model MFC07M3FW0. Any one?
Gere knutson
  • Freezers Master
  • 842 Answers
According this model you have a 7 cubic feet freezer.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Aug 18, 2014
4 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
  • 417 Answers
no sorry try and see if the part already has a part number on it.
Thanks J
Posted on Feb 16, 2008
farfield
Farley Redfield
  • 462 Answers
SOURCE: Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
Posted on May 29, 2009
Anonymous
  • 288 Answers
SOURCE: Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Posted on Nov 15, 2009
Need lowest actual temps achievable by various upright freezers.
no rule of thumb
maybe if you got a different thermostat that has a lower setting than standard
however as upright freezers are very bad freezers compared to chest type freezers the lowest reading will be around the -35 degrees C
Why very bad -- every time you open the door you dump 20 degrees out onto the floor and the temp difference is more pronounced than opening the lid of a chest unit which keeps all of the cold in the unit
remember the colder the setting the more the compressor is working
Jul 08, 2018 | Freezers
Specs for arctic king chest freezer model w8s-185c1ws how many watts does it use
Specs don't appear to be available. Freezers are usually rated in amps. To find the watts, multiply the amps by the voltage. Would also depend on the cubic feet of the freezer as the bigger the freezer, the more amps the compressor draws.
Only thing I could find is its energy star rating.
Find and Compare Products
Jul 09, 2016 | Freezers
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
I am looking for the specifications like cubic footage on my chest freezer
The model number indicates the cubic footage of the freezer.
Example...model number xyz186xxww.,would be 18 cubic feet.
Post your model number on this thread for an exact conversion.
Sep 18, 2010 | Freezers
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Chest freezer
Thanks J
Jan 07, 2008 | Freezers
Freezers Logo
121 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
