How do I remove 1start123.com from my computer
This program is the worst experience I have ever had short of a crash
Posted by mehan on
Andrew Strydom
    New Friend:
    Problem Solver:
  • 18 Answers
If its a toolbar click here:
How to Remove Toolbars
If its a program:
1.Open Control Panel
2.Click Uninstall a Program
3. Find 1start123.com in your program list
4. Right Click on it and hit uninstall
5. Follow the uninstall process clicking yes and then finish or close
If its a Site Preloaded when you open your browser click here:
How to Change Your Startup Page in Your Internet Browser for Windows
Hope i help
AS
Posted on Aug 17, 2014
Freemake video converter closing or crashing when on another page?
From my experience working with their Video Converter.
About 2 years ago I was under WinXP. I thought that my system was clean, I wasn't worried about anything. But just unexpectedly I had several crashes of my favorite programs. I ran CCleaner and fixed it.
Than I bought a new machine with Win7 and I had some troubles with crashing of their Converter. I contacted with [email protected] and resolved my situation within 2 days. Now I'm happy!
Nov 14, 2012 | Freemake Video Converter
Why does chrome keep running slow or crashing
Possible solutions:
Remove various apps that are part of your Chrome program. If you have a lot of apps, they can conflict with one another (I had this experience). Remove some and Chrome might work a lot better. Reduce the number of different programs open on your computer. Depending on the amount of RAM you have, having too many programs open can slow everything down. Uninstall and then reinstall. This will give you a clean starting point.
Aug 03, 2011 | Google Chrome
Abs light is stays on. The air bag light stays on as well. I have a 2004 Ford exploer sport trac 4x4
Get the fault code.
DTCa LFCb LFC Priority Description B1318 - - Ignition Voltage Below 9 Volts - - 1 RCM Disconnected, Inoperative, or Lost/Low Ignition Feed B1342 24 2 RCM is Faulted B1231 19 3 RCM Crash Data Memory Full B1921 21 4 RCM Bracket Ground Resistance High C1414 29 5 Incorrect Vehicle Identification Code B1887 15 6 Driver Air Bag Circuit Shorted to Ground B1916 15 7 Driver Air Bag Circuit Shorted to Battery or Ignition B1888 16 8 Passenger Air Bag Circuit Shorted to Ground B1925 16 9 Passenger Air Bag Circuit Shorted to Battery or Ignition B1932 32 10 Driver Air Bag Circuit Resistance High B1933 33 11 Passenger Air Bag Circuit Resistance High B1934 34 12 Driver Air Bag Circuit Resistance Low B1935 35 13 Passenger Air Bag Circuit Resistance Low B1901 14 14 Front External Crash Sensor Shorted to Ground B1941 41 15 Front External Crash Sensor Open Circuit or Short to Battery B2444 48 16 Driver Side Crash Sensor Internal Fault B2445 49 17 Passenger Side Crash Sensor Internal Fault B2441 42 18 Driver Side Crash Sensor Mounting Fault B2440 43 19 Passenger Side Crash Sensor Mounting Fault U2017 44 20 Driver Side Crash Sensor Communication Fault U2018 45 21 Passenger Side Crash Sensor Communication Fault B1993 36 22 Driver Side Air Bag Circuit Shorted to Ground B1992 36 24 Driver Side Air Bag Circuit Shorted to Battery or Ignition B1994 36 26 Driver Side Air Bag Circuit Resistance High B1995 36 28 Driver Side Air Bag Circuit Resistance Low B1997 37 23 Passenger Side Air Bag Circuit Shorted to Ground B1996 37 25 Passenger Side Air Bag Circuit Shorted to Battery or Ignition B1998 37 27 Passenger Side Air Bag Circuit Resistance High B1999 37 29 Passenger Side Air Bag Circuit Resistance Low B1892 - 30 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open B1891 - 31 Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition B1869 Tonec 32 Air Bag Indicator Inoperative B1870 Tonec 33 Air Bag Indicator Shorted to Battery - - - No Communication With the Restraints Control Module (RCM)
a DTC: Diagnostic trouble code
b LFC: Lamp fault code, flashed on air bag indicator.
Apr 21, 2011 | 2004 Ford Explorer
I had the microsoft picture it 7.0 program for years. my computer crashed and i can't find the program. i love the program. can you please help me
You really need to give more details 'what operating system is it ie; win xp , vista or win 7 and what happened after the crash was the computer repaired or restored or was it reformatted etc? one thing to try is to just do a basic search using the windows file search program --go to start - search for files- type in the file name and click search or use advanced search and search for all files with the specific key words of the program IE:picture it 7.0 or Microsoft picture it -- hopefully it will bring up all the files related to what you are looking for -if it does then look for the actual application files and find the directory it is located in ---example -- c/windows - system 32- etc you should be able to start the file from the actual file folder and then create a desktop short cut to it .some times after a crash shortcuts are lost while the actual program is still installed.
I hope this helps
Andrew
Mar 26, 2011 | Microsoft Computers & Internet
My phone says crash dump analyzer and nested crash
Hi, Kyocera is one of the worst companies you can buy. No offense Kyocera. The Crash dump usually happens on UT STARCOMSS and the crowd lovable k132 when you do more than two thigns at once. You have replace the phone or give it to kyocera for service.. They perform phone upgrade
Sep 14, 2009 | Kyocera Switchback KX21 Cellular Phone
Is there a fix for Windows XP Home SP3 crash? my computer crashes all the time, i can format but i thought that there may be a fix because this is a known issue and many people have the same problem. If...
To make it short, you can try un-installing SP3, but the reason you computer is crashing is due to a program that is having incompatibility issues. That doesn't meant that your programs can run on SP3, it mean your programs and maybe even your drivers were install when you had SP2 and they didn't like the service pack update. You can definitely try to find which programs or driver are causing the problems but I recommend. Do a full format(non quick) and then a fresh install of windows and then update windows, and also try to download the latest drivers from the manufactures website and then install your programs.
**So yes I recommend an operating system re-install.
May 14, 2009 | Microsoft Windows XP Home Edition
Turboc not working on asus m2n-mx motherboard
Right click on tc.exe click on screen tab check out window instead of full screen under usage options.TC will run in window mode.Then press Alt+Enter to fullscreen.
No solution yet for c graphics programs crash on nvidia chipset.(yeah problem is in nvidia chipset not in MoBo).
Nov 05, 2008 | ASUS M2N-MX Motherboard
Freezing/crashing
98% device get freezes because not enough memory to run programs, XDAII mini do have only 64MB, if you have installed many application on device better move them to SD Card. Windows mobile will not close application as you click on close button you have to goto "Running Programs" and stop unwanted running programs. or else try "SPB Pocket Plus" if you close programs and remove them from memory. as i experience if you installed few app's and few games you will get less than 20MB to run application its really not enough.
Dec 05, 2007 | O2 Xda II mini
Dreamweaver 2004 MX crashes
I think your Win is the source of the problem.
At first renistall your DW,
If your problem continue
Reinstall your OS
of course i suggest you to use some Optimize softwares, maybe they can help you
Nov 19, 2007 | Macromedia Dreamweaver MX 2004
Computers & Internet Logo
197 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
