I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
The link above may assist you in diagnosing your problem or you may need a house visit from a certified technician. Such issues are uncommon and would need some detective work. Sorry I am unable to assist you any further.
signal means freeze cycle is over 60 minutes. Look for: stuck float, water valve leaking water into sump, hot gas valve leaking hot gas into the cool side of the refrigeration system. start there.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Sound as though you need a defrost timer that is located around temp control and light in fridge side.If it is faulty it will not go into a defrost making the freezer ice up and cause alot of trouble.hope i helped thanks:)
