Question about Smith Corona Wordsmith 100 Typewriter
Carriage does not return to left on Smith Corona Typewriter
When typing the carriage moves to the right side of typewriter, however, the carriage will not return to the left side. Typewriter is an electric Smith Corona (SC110)
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Posted on Oct 29, 2007
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Posted on Dec 31, 2008
Anonymous
  • 45 Answers
SOURCE: bought a great smith corona coronet electric 12
Try going to www.willrepairservice.com for a manual for your Smith Corona typewriter. Or, you can go to Google and type in "Will Repair Service", go to the first link displayed in the results. Best of luck to you!
Posted on Jun 07, 2009
male_28_cam
Aruna Singh
  • 1555 Answers
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
Posted on Jun 21, 2009
Anonymous
  • 5 Answers
SOURCE: SC110 Typewriter won't "return"
Here is the locatioin of the manual
http://www.smithcorona.com/pdf/WS100Man.pdf
Posted on Aug 01, 2009
Why does paper not advance to next line when carriage returns?
There might be a setting for how many lines it moves when the carriage gets to the end. It is mechanical so you'll see it!
Sep 01, 2014 | Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Carriage lever return
if the lever is loose you should be able to lift it up and down if so look for the pivot screw see if has LOOSEND UP
Nov 02, 2013 | Smith Corona Vintage Classic 12 Manual &...
L.C. Smith & Bros. typewriter No. 5 Margin setting
Make sure the carriage lock switch isn't on (presuming it has one). A carriage lock switch prevents the carriage moving when in transit (say, inside its case). These switches are usually located on the right hand side of the carriage, slightly underneath.
Gordon
Jul 19, 2010 | Royal MS 25 Typewriter
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Was the carriage return ever on the right?
I have worked on typewriters fo 20+ years.
The only typ's I know of that had the return on the right hand side are all the manual typ's
Feb 19, 2009 | Brother ML-500 Typewriter
Carriage return problem
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Carriage Return doesn't work. Everything else works fine; but it will not return the carriage when the return key is used.
check to make sure no forien objects are in machine preventing the carrier from moving, with the mach. turned OFF you should be able to move the carrier by hand from one side to the other
Jul 09, 2008 | Smith Corona Wordsmith 100 Typewriter
Smith Corona Wordsmith 100 Typewriter Logo
473 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Keysor
Level 1 Expert
STEVE SPAM REMOVER
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
