Question about Cameras
KODAK EASY SHARE C433 ---I HAVE INSTALLED BRAND NEW BATTERIES AND ITS SHOWING A YELLOW BATTERY SIGN
HAVE INSTALLED BRAND NEW BATTERIES BUT THE YELLOW BATTERY SIGN IS SHOWING UP AND I CAN NOT USE THE CAMERA
    Master:
  • 969 Answers
Clean the positive contacts, new batteries not up to charge
Posted on Aug 17, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Jey
  • 9 Answers
SOURCE: My kodak easy share z1275 wont power on. I have
read this post, worked for me!
http://www.fixya.com/support/t3489422-camera_will_turn_second_go
Posted on Dec 11, 2009
Anonymous
  • 30 Answers
SOURCE: how can i transfer pictures on my internal memory
u need the usb cable the camera came with
Posted on Jan 13, 2010
Ty Price
  • 11967 Answers
SOURCE: zoom lens stuck in out position, kodak C875 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Shows low battery, even after installing new batteries. will not work.
The best batteries are rechargeable NiMh batteries of the ENELOOP (Sanyo) type.
These batteries have a very, very low discharge. Some other brands have such types too.
Oct 21, 2010 | Konica Minolta DiMAGE S414 Digital Camera
My Pentax Optio 50 digital camera almost immediatelly shows that even brand new batteries are empty (red sign) and practicly not possible to make one photo.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Jun 15, 2010 | Pentax Optio 50 Digital Camera
Kodak C180 for Xmas - The pic of the battery shows
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). The batteries that was in your pack when bought are only test batteries and not rechargeble.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
The camera will not load a tape. Without a tape installed the loading mechanism works as it should. when a tape is placed in the camera it does not retract into the camera but opens back up as if to eject...
Symptom shows Dew sensor is activated and most probably you will see water-drop yellow sign flashing in LCD.
Remove battery / power source from camcorder and leave it for 1-2 hours, reattach battery/ power to camera and turn it on and check.
Thanks.
Nov 05, 2009 | Sony Hi8 CCD-TRV138 Camcorder
[email protected]
Digital cameras require BRAND NEW batteries.
Look for 2200mAh or higher batteries.
Brand new duracel or Energizers will only last about ten photos. Look for Rechargeable batteries, perhaps from a camera store.
If brand new batteries don't work, then the camera may be dammaged.
Also, be shure the plus and minus ( +\- ) signs line up as pictured on the camera too.
Cheers,
Richard.
Oct 13, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
False low battery message -- batteries are brand
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Aug 17, 2009 | Canon PowerShot A1100 IS Digital Camera
Erratic Low Battery Warning
Voila fixed.
Nov 05, 2008 | Canon PowerShot A560 Digital Camera
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
Low battery indicator
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
