Question about Toshiba E-Studio 356 Multifunction Copier
Toshiba E-Studio 356 Copier error C440 - Toshiba E-Studio 356 Multifunction Copier
Posted by rodel on
shohel rana
    New Friend:
  • 16 Answers
Can do [1] cancel 0+5 together touch and main switch on 400 touch print switch touch 0 touch inter-up touch and do off on [2] change thermostat [3]heater bod chang
Posted on Aug 18, 2014
5 Related Answers
patrick hopkins
  • 132 Answers
SOURCE: I have a C440 error
switch off the macine hold down 0+8 while you switch on the machine when the macine is in test mode enter 400 and change the setting to 0 and enter it switch off the machine and wait 30 seconds then switch on the machine you should be up and running if not change the thermistors and thermo fuse
Posted on Mar 09, 2011
Everett Lin
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
Anonymous
  • 30 Answers
SOURCE: I got a C440 error code sub code "7" with Toshiba
Hi how are you this is jack ...([email protected])..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Posted on Aug 14, 2010
djuksoni
Branko Djurdjevic
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
fivemayur
Sanjay Parihar
  • 414 Answers
SOURCE: I have a Toshiba 350 copier ans it has a error code c440
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
CN455/456).
please vote me.
Thanks
Best Regards
Posted on Aug 23, 2012
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Black Toner Cartridge Not Recognized.?
Check the contacts on the toner cartridge and in the printer are clean and shiny. They also must have no dent.
We on Fixya only try to answer questions via this page. We don't send mail.
Mar 13, 2015 | Toshiba E-Studio 356 Multifunction Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Toshiba e-356 error C440
He did not find 400 benefits and pressure on the Toshiba 356se type
Feb 16, 2014 | Toshiba E-Studio 356 Multifunction Copier
C440 error
chik tha power suppl bord
Nov 15, 2013 | Toshiba E-Studio 456 Copier
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
[email protected]
Aug 12, 2012 | Toshiba Estudio 200L Copier
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 356 Multifunction Copier Logo
913 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
