IBM Infoprint 1332 Laser Printer Logo
A
Anonymous Posted on Aug 17, 2014
Where there a IBM inforprint 1332 printer driver for window 7?
Chris Hardgrove
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Aug 17, 2014
Chris Hardgrove
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
12131
Points
145
5 Related Answers
Anonymous
  • 31 Answers
  • Posted on Aug 17, 2007
SOURCE: Maintenance shedule error
Power off the printer and hold down the two top right buttons and power the printer back up. You will be taken to a menu that you will be able to scroll through. Look for the "Maint Count Reset" option and press the "enter or go" button and reset the count.
Anonymous
  • Posted on Apr 17, 2009
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Anonymous
  • 26 Answers
  • Posted on Dec 09, 2009
SOURCE: driver IBM printer 4610 suremark for windows xp
You can find the driver here: http://www-01.ibm.com/support/docview.wss?rs=219&uid=pos1R4000123
Anonymous
  • 385 Answers
  • Posted on Sep 07, 2010
SOURCE: somebody has a Manual of IBM 1332 infoprint
drivers and owners operating manual are almost always free for download from manufacturer's website. look for support or help sections.
Anonymous
  • 34 Answers
  • Posted on Oct 04, 2010
SOURCE: IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
tip
IBM Infoprint 1332
I want Dwn load driver IBM Infoprint 1332
Somebody has a Manual of IBM 1332 infoprint printer?
1helpful
We need driver
Visit ibm.com then click Support & Downlaods.
Select the category Printing Systems.
Select your printer in the sub category.
Then click the blue enter arrow.
The #4 universal driver works best for most windows systems.
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
PRINTING ON A BLACK BACK PAPER
DYE YOUR RIBBON WHITE SPORT!
White ink the ribbon, should do the job, never seen anything comercially for it.
Top IBM Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
