Question about Camping, Backpacking & Hiking
Want to learn how to set up 3809 Rothco tent - Camping, Backpacking & Hiking
Posted by juan on
How do i find the instructions to set up a western field tent from Montgomery wards
instructions to set up a western field tent Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do you set up Montgomery Ward Western Field tent
https://answers.yahoo.com/question/index?qid=20090705144031AAE0SOM
Setting up Vintage Umbrella Tent wmv
western field tent from Montgomery wards Google Search
Jun 12, 2016 | Camping, Backpacking & Hiking
How to tie a rope around a large tree
Trucker's knot. I use this because it provides great tension and offers a quick release. It's great for mainlining a tarp or even a clothes line.
Oct 26, 2013 | Camping, Backpacking & Hiking
I am trying to learn how to tie a taut line knot but am having trouble. Any suggestions?
Watch this YouTube video for a practical step by step guide to tying taut line knots.
Sep 10, 2012 | Camping, Backpacking & Hiking
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    Square tent with 2 types gazebo poles, varenda, 2 side windows
    the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
    shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
    May 04, 2010 | Wenzel 18'x10' Sycamore 3 Room Tent
    How do you change the batteries in the exersaucer circus tent?
    on the back you should see a screw that is by its self try un screwing it and replaceing tyhe battery
    Apr 03, 2009 | Evenflo ExerSaucer SmartSteps Active...
    Camping, Backpacking & Hiking Logo
    89 people viewed this question
    Top Camping, Backpacking & Hiking Experts
    Tom Chichester
    Kardoc
    ray gallant
    Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
