Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
One solution that i read was "i had two fv700 do the same thing. i replaced the nimh battery packs in both radios and replaced with triple a batteries and both started working properly"
This has worked for me also - aaa batteries fit right in - it's just a drag that it's not rechargeable anymore - I wonder if 3 rechargeable aaa's would work?
Not certain what model radio you are using to transmit, it is possible your radio has a Qt filter. If so, set it to zero. If this does not solve the problem, try setting your Code to zero also.
Check your "code" setting. You may be on the same channel, but different codes. The code is the smaller number. Check your owners manual if you have one for resetting the radio to the factory default settings. This will clear any programming issues.
The T5000 Talkabout radio default settings are not the same as the CP100 and CLS. The CLS and the CP100 UHF are capable of being programmed to match one another on several frequencies, however, the TalkAbout T5000 is not capable of any of them.
The Talkabout radios, as a general rule, are limited to FRS and GMRS frequencies. The CP100 and CLS are from the business and light consumer divisions. They will do most of the common 56 UHF business frequencies.
If you would like to look at the frequency charts yourself, here are some links.
