Question about Frigidaire Refrigerators
Where is theice maker s on/off switch lcaed
Ice maker not orking
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good afternoon friend, thank you for your post!
I see you are asking for the location of the on and off switch for your Frigidaire refrigerator's icemaker. Depending on your model the icemaker off switch will either be the wire arm or a power switch located on the icemaker. If you have the model with the wire arm flipping the arm up will cut off the icemaker and flipping it down will turn it back on. I hope this is helpful. -Matt
Posted on Aug 19, 2014
3 Related Answers
Anonymous
  • 1122 Answers
SOURCE: Ice maker not making ice. I have .344 ohms at the solenoid.
your inlet water valve on the back of the frig. has failed and needs to be replaced-mike
Posted on Nov 09, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: where the water comes into the freezer part of theice maker
Really sound to me that the water control valve is defective and will not close. Pull refrigerator away from wall and on the water control side for the ice maker disconnect the two wires. If the water continues to flow the valve is stuck open and will need to be replaced. Let me know, Sea Breeze
Posted on Jul 22, 2009
Anonymous
  • 40 Answers
SOURCE: theice maker in my refrigerator makes thin shallow
that indicates it is not getting enough water inthe ice mold most icemakers have a water adjustment screw behind the cover if it cant be adjusted the inlet valve may need replacing
Posted on Jan 22, 2010
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
Ice maker not making ice. There is no jam and all swithes are in the on position. I think a hose has disconnected, where can I find the hose to check it
Icemaker not working: Check the shutoff arm, the shutoffarm fails to move upward when the ice bucket is full. Check the water pressure. If thereis not enough pressure, the ice maker will not have enough water to make ice.Ifwater flow pressure is good, check solenoid valve activate and also it'scleaned. Locate your ice maker, remove theice bucket. Pull the cover off the end of the ice maker. Locate the holes "V"and "L". Take a paper clip (jump clip) and tape. Straight the clip and put tapein middle. Hold the taped side and insert the clip into "V" and "L". This sendsthe power to water valve. If water goes into ice-maker, water valve is good. Ifnotreplace solenoid. Check thefreezer temperature. The proper freezer temperature should be around 5 degrees.The warmer it is in the freezer, the more difficult it is to make ice. thanks,helpful?
Mar 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Theice maker in my refrigerator makes thin shallow
Jan 17, 2010 | Frigidaire PLHS67EGSB Stainless Steel Side...
Where the water comes into the freezer part of theice maker
Jul 22, 2009 | Refrigerators
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Nov 08, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Not making ice
canyou acess theice amker assy itself??
can you look intor the icemaker make sure nothings blocking ice maker from turning(ice cubed jammed in )
look into the fill tube make sure itsnot frozen
thinkin htis machin hasan electronic "eye" if so htere a trouble shoooter under the kickplate explaining the mechanism
lastly theres a white cover plate on the front of the assy. remove the cover and loook at the white gear in the center of unit. look real close at the tabsholding that gear on.MOST common causeof failure is the ice torques the main gear and those tabs snap. if htats the case , replace the ice maker assy.
Mar 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
Mar 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Get water, but no ice
Mar 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
