Question about Apple iPhone4 4G iPhone 4
How do i unlock my iphone 4?
I gave my old iphone to my daughter and she has disabled it. screen now shows iphone is disabled try again in 23,371,398 mins. I do not have the IMEI number and I cannot unlock with itunes, icloud our find my phone.
Rohan Jethi
    New Friend:
    Problem Solver:
  • 16 Answers
Switch the iphone off, hold the home button and then connect your iphone to your computer. the iphone should go into "recovery mode" from there you can restore your phone and use it easily
Posted on Aug 25, 2014
2 Related Answers
haiiamnewhere
  • 20 Answers
SOURCE: unlock imei for iphone 4
I will help you to unlock I-Phone 4 from network lock,get the remote unlocking service from here Unlocking4u.com and unlock it from network lock.
Posted on Jan 31, 2012
Mesmo
Canaan Hoffman
  • 164 Answers
SOURCE: i am from india i have iphone 4 it is from uk. i
Take it to a local retailer. Its possible that the IMEI was blacklisted and possibly marked stolen on accident. Check with a local retailer of cellular provider to see if they can remove it off the blacklist.
Posted on Oct 20, 2013
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
My daughter gave me this apple iphone six it is at activation lock screen she gave me her id but she cant remember her password what can i do
If the iPhone is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. The following guidance will show you how to unlock a disabled iPhone with iTunes.
How to Unlock Disabled iPhone with without iTunes
Dec 05, 2016 | Apple iPhone 6
My daughter has 4gotten her passcode to her iPhone 4s..... Trying to reset it but 4 some reason or another her on/off button don't work so not sure if there's another way to do this ??
Hi Natalie, The links below are YouTube videos showing how to bypass iPhone password lock, Also there's videos down the right side of the link that may help as well...........CHEERS..
How to unlock any iphone without password
How To Bypass Any iPhone Passcode
May 12, 2016 | Cell Phones
I put in wrong code and now it says disabled connect to iTunes but I set the phone up with wifi so how do I get in my iPhone?
Your iPhone is currently on disabled mode after entering wrong combination of password. There are several ways to gain back the access to your iPhone:
First Method: iTunes
1. Using your computer, open iTunes where you have recently backed up your iPhone.
2. Connect your iPhone. Once your iPhone is detected, a notification will appear to enter your passcode. Note: If the lockscreen doesn't show, proceed to next method.
Second Method: Update
1. While your iPhone connected to iTunes, powered on. Hold down the Power key + Home button simultaneously until the screen off, keep on pressing the Home button then release the Power key until iTunes detected that your iPhone is on Recovery Mode. Note: An iTunes logo will appear on the iPhone when Recovery mode is enabled.
2. On iTunes, click on Update iPhone. It may take a while to download the software, so leave it for a while connected until the installation complete.
3. Once updated, try unlocking your iPhone. Note: If you still can't unlock your iPhone proceed to next method.
Third Method: Restore (last option)
1. If method 1 and 2 fails to unlock your iPhone. Then try to restore your iPhone into its factory default and restore your backup after.
2. Go to recovery mode. See method 2 step 1 process to enable recovery mode.
3. Then choose Restore iPhone. Note: Restoring your iPhone will delete and remove all of your data including apps, music, photos, messages, contacts, notes, etc.
4. It may take a while to download and install the software, so leave your device connected until the process complete.
5. After your iPhone has been restored, choose restore from a backup or iCloud, then wait until your iPhone successfully synced your old data.
6. Try unlocking your iPhone.
-joshd
Mar 28, 2016 | Apple iPhone 5c
My iPhone has disabled how do I unlock it
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't ... If it doesn't, learn what to do. Once the sync and ...
How to remove/reset any disabled or Password locked ...
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
iTunes will alert you that it has detected a device in recovery mode. 6. .... easy and fast to activate/unlock/jailbreak/bypass every iphone from 5s to 6s without having any problems. use "newunlockiphone,net". .... +Clair Glen My iPhone is disabledfor 23,760,796 minutes. ... Do you need an ITUNES account?.
Top Ways To Unlock iPhone Disabled - YouTube
? 2:35
https://www.youtube.com/watch?v=KiWp28QTToQ
Jan 1, 2014 - Uploaded by CocTubes
How to Unlock Your iPhone When Its Disabled .... me use myfingerprints like it normally does. of anyone has anyway of helping.... What to do?
Dec 16, 2015 | Apple iPhone 4 Black Smartphone
How to unlock iphone 4 passcode lock from at&t?
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
If you want to try it yourself, feel free to read the next site
How to Reset Forgotten Password for an iOS Device
Jul 27, 2014 | Apple iPhone Cell Phones
How can i enter password on iphone after it is disabled
https://www.apple.com/support/iphone
Jul 02, 2014 | Cell Phones
My iphone is disabled
Hi, what is the generation of your iPhone? Your iPhone is disabled because you tried to unlock it but entered the password incorrectly too many times. You can restore your phone in iTunes then jailbreak to unlock. Please provide more information about your iPhone.
Nov 10, 2011 | Apple iPhone Smartphone
Apple iPhone4 4G iPhone 4 Logo
121 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
