Haier BC112G Wine Cooler Logo
A
Anonymous Posted on Aug 16, 2014
Haier HVFM20ABB how to fix not working - Haier BC112G Wine Cooler
1 Related Answer
Anonymous
  • 76 Answers
  • Posted on Sep 11, 2008
SOURCE: I have a Haier HVFM20ABB
If the motor still runs its a gas problem.
You need to get a re gas done on your fridge...
Later...
Wouter...
Is any P6R8MC start relay a replacement for P6R8MC OR0304?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwje75XzxZSCAxVOmokEHXxQBfsQFnoECBsQAQ&url=https%3A%2F%2Fwww.amazon.com%2Fp6r8mc%2Fs%3Fk%3Dp6r8mc&usg=AOvVaw3s7ZWczicVttYruKA_j6FX&opi=89978449
Ice build up
Normal to have a bit of ice. Set the temp to 0 for a few hours every week. Check Seal is good all round the door.
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
2helpful
I have a HVFM20ABB wine cooler and the unit is not getting cold. Is there step or items on the cooler that could be checked to see why it isn't geting cold? There is a noise that it makes when it is on,...
rer
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2answers
Clicking sound and not cooling
compressor grounded. replace relay or compressor
Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
7helpful
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
I have a Haier HVFM20ABB that won't cool anymore and the motor is getting very hot. Any ideas?
Later...
Wouter...
Top Haier Furniture Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Haier Furniture Expert? Answer questions, earn points and help others
