Lift off the rubber cover. On some turntables, you can pull the whole metal platter straight-up now. Put the belt on the outside of the bottom of the platter and drop platter back into the turntable base. Do NOT put the rubber cover back on yet. There should be one or two openings in the platter where you can see the pulley for the motor. Slowly rotate the turntable platter until the opening is over the top of the motor pulley. Now use a nail file to gently pull the rubber belt over the pulley. It should spin freely now. Now put the rubber cover back on and try it out. Belts are available from MCM Electronics and over online vendors. Let me know how it goes. Good luck.
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the
motor spindle by using your fingers to turn the round shaft which rotates
freely. Remove the rubber mat off the platter. Place the belt around the outside
of the drum on the bottom of the platter.
From the top of the platter, place your finger in one of the platter
holes and tension the belt so it will not fall off or twist. Griping the
platter trough the holes while keeping tension on the belt place the platter on
the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over
the motor spindle. Replace the rubber mat on the platter.
