Question about Bose Companion 3 Computer Speakers
How to Connect BOSE Companion 3 Speakers to Magnavox HDTV
Magnavox Model 29ME403V
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: can i connect my bose companion 5 to a lcd t.v
yes use an auxilliary
Posted on Jun 17, 2009
Anonymous
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
Anonymous
SOURCE: Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Posted on Nov 14, 2009
Anonymous
SOURCE: Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Posted on Nov 18, 2010
Anonymous
  • 100 Answers
SOURCE: I have the Bose Companion 3 Series II speakers. I
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Posted on Dec 16, 2010
Testimonial: "Thank you for the prompt response! I noticed that the static goes away completely at a higher volume. Thanks again."
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
The transformer on my Bose Companion 3 may be dead
you need to change the adapter . there is no way you can repair
Jul 07, 2010 | Bose Companion 3 Computer Speakers
How do I connect to an LCD HDTV?
hello theltman.just buy an auxillary cord. one end has a red and white connectors which you insert to the tv and the other end has a single connector that you insert to bose comapanion 5. happy listening.
Dec 30, 2009 | Bose Companion 5 Multimedia Speaker System...
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Jan 06, 2009 | LG 42LG50 42 in. LCD HDTV
Bose Companion 3 Computer Speakers Logo
139 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
