TRYING TO LOCATE SPIDER ARMS, REPLACED SHOCKS, STILL MAKING NOISE ON FINAL SPIN, NEED SPEC TO LOCATE PARTS, IS THEIR A BRACE FOR THE BACK TO HOLD THE DRUM, MY MACHINE HAS SPRINGS IN FRONT, FOR BRACING.PLEASE HELP
Hey friend, thanks for your post!
I understand you are trying to locate the location of certain parts within your Frigidaire washer. I have included a link to your parts manual which show the components inside of your appliance. If you continue to have difficulties I would reach out to a professional for additional assistance. Best of luck! -Matt
Frigidaire Manual Search Results
SOURCE: Terrible noise on spin Cycle
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
SOURCE: very loud noise during final spin
Possible your spider arm, which you cannot see, has come loose, or has broken. Its a major fix.
SOURCE: Hi, our washing machine started making very loud
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
SOURCE: banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
