HP DeskJet F380 All-In-One Printer Logo
Question about HP DeskJet F380 All-In-One Printer
LIGHT BLINKING INK LIGHT BLINKING
Epson L361 Service Required Solution Red Light Blinking
The Epson printer red light blinking due to various reasons. The Epson printer light blinking when you have paper jammed, low ink tank, Epson printer printhead overloaded, when printer fuser not working and more.
Fix the Epson printer red light blinking error with simple methods:
·Clear Paper jammed in printer
·Check printer Ink cartridge
·Check printer network connection
Follow the more troubleshooting methods to fix the Epson printer red lights blinking issue.
I have just replaced ink cartridges for HP Officejet 7000 E800 and the ink lights are just blinking on the printer. What do I need to do to resolve this problem?
After replacing the ink cartridge, the HP Printer light blinking that means your printer has some another technical issue. The HP printer blinking different type of lights. Let's discuss the reasons behind the HP printer lights blinking issue:
When your HP Printer blinking orange light that means the problem with your printer ink cartridge, toner or may be corrupted configuration settings.
If your HP Printer blinking Blue Light, it indicated the HP Printer isn't setup on the wireless network.
Find the right solutions here and fix the HP Printer lights blinking issue.
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
Blinking light
Try to Reinstall the cartridge , if the blinking continue , try to remove ink then unplug the power cord and reconnecting power cord with ink then see blinking for ink , then install the cartridges , if hope this help
Mohamed Hejazi
Afaqnama - Tripoli, Libya
[email protected]
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
1helpful
What might be a possible cause, that my f380 printer.. could not print... can you help me pls.?
see the light blinking? which light, paper or ink indicator.
if ink/cartridge indicator is blinking, you need to replace the cartridge. if no blinking lights it could the printer mainboard is out of order due to ink spilled
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
1helpful
Ihave a blinking black ink indicator light. I have a flashing light on my display ;
Not sure what type printer you have since you didn't mention that, but on most printers when the light is blinking the ink is low, if it stays on solid it is about totally out of ink.
2helpful
2answers
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Clive
Clive
Ben Johnson
