In recording a phonograph record, when I press CD Record, I get the message FORBID on the screen
So you want to directly record phono output on a cd, without on a dd-player? . The phono pre-amp does not only makes the signal voltage higher, it has a built a built in equalizer which is necassary since the recordplayer has a cutoff low and high frequency part.
And besides that is the signal from a needle way too small to work with, so whole the signal get amplified to what we call a line level. And only that signal is strong enough to work with. And if you can record it directly on a cd, depends on which formats your recordplayer understands.
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
