My kdl-32l5000 has a diode shorted in the power supply but i cant find out what kind of diode it is the location number is ''D6103''
Set does not come on, no light on the front i check the power supply and found an open resistor and a shorted diode
    Sergeant:
  • 213 Answers
Look for another diode on that circuit board that looks identical and take a reading in ohms with no meter and that the diode you will need to replace the resistor it should say on the circuit panel look with a magnifying glass
Posted on Aug 16, 2014
  • Raymond
    Raymond Aug 17, 2014
    i need to know what kind of diode is it because it reads a total short and all that is marked on it is 4H
6ya staff
SOURCE:
My Sony Bravia LCD TV will not turn on.
If no voltages,then replace all main capacitors,power ic and optoisolater ic,do not forget the rectifire diodes/bridge and the output diodes.
Nov 25, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Sony model kdl-32l5000 only works by unplugging and plugging back after about 5 minutes
power supply may need recap try with a hair dryer when tv in stanby to heat a bit without unplug it if after heat it will start?
Sep 14, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Picture failure on my sony bravia kdl 32l5000
First check it by connecting a DVD player or games console to it to see if the picture behaves with them feeding it. I will assume they also fail. When it fails try going up a channel and see what happens then. So If the backlight (which is a few simple flourescent tubes) also went off AND the sound went off I would say there is a fault in the power supply, inside the TV, but the sound stayed on so this is a very unusual fault. I think it may be switching to a mode of operation where the picture is deliberately suppressed. A factory reset should have cleared this so there is an electronic problem, for most TVs its not cost cost effective to repair any of the internals.
Dec 19, 2013 | Sony Bravia L-Series KDL-32L5000 32-Inch...
Bad power supply?
First of all, please ensure that the power outlet is ok. During such power surges, normally the power outlet gets affected. Try the TV on a different power outlet. The relay clicking on/off could be due to some components short in the primary supply.
Aug 26, 2012 | Sony Bravia L-Series KDL-32L5000 32-Inch...
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Where is the convergence power supply located on a RCA P52960?
TAKE A CLOSE LOOK AT THE LABEL ON THE BACK OF THE SET WITH THE MODEL NUMBER, IS IT MARKED PTK195?
THE PTK 195 uses a power supply mounted above the main boards and is about 10 inches wide and 4 inches deep.
It is very common on this model for one of the ten diodes to be shorted; confirm it is a 195 chassis and I will tell you how to locate the two diodes that fail. They supply voltage to the convergence circuit and I have seen dozens where one of them shorts.
Let me know what you find; is it a 195 chassis?
If this information has helped you rate this solution as I do this here for free, rate it "very helpful".
If it is a 195 chassis let me know and I will pinpoint the location of the two diodes and tell you how to check them.
REGARDS, SD TECH
Aug 10, 2010 | RCA P52960 52" Rear Projection Television
KDL-32L5000 model cracked screen
Someone or something impacted the screen. There is absolutely no other way this could have happened. The cost of replacing the panel will far exceed the cost of a replacement TV.
Mar 13, 2010 | Sony Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
