Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
A
Anonymous Posted on Aug 16, 2014
Samsung vrt front load washer
Washer does not rinse or spin
John Sweeney
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
  • Posted on Aug 16, 2014
John Sweeney
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
5
Helped
14368
Points
224
Check operating troubleshooting questions on instructions manual
rcbeltz
Level 2:
Scholar:
  • Expert 85 Answers
rcbeltz
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
41852
Points
281
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
5 Related Answers
Anonymous
  • Posted on Sep 03, 2009
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
vickyc
  • Posted on Apr 22, 2008
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Anonymous
  • Posted on Jan 23, 2010
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Mar 03, 2010
SOURCE: samsung 1215j front loader
Check pumping ok if not clean filter
Anonymous
  • 43501 Answers
  • Posted on Aug 28, 2010
SOURCE: my samsung vrt front loader
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer spin cycle error
This is a common problem, check to make sure machine is level an not on a lean, also check the machine feet are all wound down so machine sits firm.if all good then it may be worn out suspension rods
Samsung VRT error code dc
dc means clog in the filter. look to the lower left front of the washer for the filter door. Take off the door and pull out the short hose. Empty the water from the hose, this could be lots of water be prepared. Then pull out the filter on the right by twisting counter clockwise and rinse the filter. Put it back together and the error should go away
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
2helpful
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
