Question about Lenovo ThinkPad Computers & Internet
My laptop wont show videos
A black screen just appears and wont load a vdeo
Posted by annette hart on
Dan Rodulfo
    New Friend:
    Problem Solver:
  • 8 Answers
Try to check for the player you are using. Try to check if it is compatible for all video format. You can download Kodec Lite Pro. This play all kinds of video formats.
Posted on Sep 08, 2014
1 Related Answer
Anonymous
  • 2600 Answers
SOURCE: My laptop wont show any video
In most cases this means a dead video processor on the motherboard. There are places you can send the motherboard to or change it out completely
Posted on Aug 31, 2009
Black screen
Recover your Chromebook
i personally don't know what's causing the problem
Jan 27, 2014 | Acer C7 Chromebook
Black screen
If everyting else appears to be working, hook a spare monitor to the video output usually on the back, if picture is okay the inverter board is more than likely bad located under the laptop screen, the other less likely is the backlight behind the display screen, but if both show the same symptoms it is the video graphics chip built into the motherboard.
Jun 12, 2012 | Acer ASPIRE 3680-2022 Notebook
Dropped my laptop
If the laptop appears to run with a black screen, hook a spare monitor to the video output, if picture okay screen may need to be changed, check cable connections and the inverter board under the screen for cracks. If both screens show the same symptoms it is the video graphics card or the motherboard itself, if the laptop is completely dead it is the main board and needs to be assessed.
Jun 04, 2012 | Sony VAIO Computers & Internet
Acer aspire 5004 black screen after BIOS completes loading
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 16, 2012 | Acer Aspire 5004WLMi Notebook
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
Black and white lines after bios screen before boot up
The issue appears to be cosmetic if the system boots to WIndows and there are no display issues using the system. Some systems I've seen have a bit of video distortion between the BIOS splash screen and the desktop. A couple things may change that. Update the system BIOS and the video driver to the most current available
May 23, 2009 | Dell Latitude D610 Notebook
Black Screen
Hi, ok friend must identify 2 things, the first thing is if the screen in black appears since it power on the equipment and changes are not obvious at the back of this one, of being like that this means that it can have faults to level of the card of video or of the LCD, now well, if it looks for a light source and at the back of the LCD to show the dark screens, it indicates that the FL Inverter this one damaged and must replace.
Jan 12, 2009 | Toshiba Satellite A105 Notebook
Black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Apr 17, 2008 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Aug 27, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
