Need directions on how to relace handle on door.
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
SOURCE: GE Spacemaker Microwave Handle Replacement
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: door handle
Normally
SOURCE: replacement part needed for GE Spacemaker Micro. (JVM1631BB004)
Appliance online store:
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
You may consider using epoxy to "glue" the handle back into place. The epoxy will be stronger than the handle itself. If you do this get the one minute epoxy
5304440323 - - - - Handle, door, black
5304440325 - - - - Handle, door, bisque
5304440324 - - - - Handle, door, white
Stainless handle not listed.. I assume it is a black handle
This has to be one of the more expensive microwave door handles I have ever experienced.
The least expensive source I found was at sears parts direct.
5304440324 Handle door white Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440324/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440323 Handle door black Price $98.97
http://www.searspartsdirect.com/partsdirect/part-number/5304440323/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440325 Handle door bisque Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440325/0022/628?pathTaken=partSearch&filterPart=&pop=flush
Note that Item 51 of the first link (top one) is the complete door assy. Also Item 60 is the door HANDLE screws (2 ea)
Just from looking at the diagrams in the first link, it appears item 56
Frame, choke cover, inner door
must be removed to gain access to the handle screws.
I looked up many sources for the handle assembly because I had a hard time believeing the handle was so expensive. Sears was by far the cheapest source.
Thanks for choosing FixYa,
Kelly
