Question about Haier BC112G Wine Cooler
Why is my Haier wine cooler not cooling at all?
I have power, I can adjust temp, I can turn on the light and I can hear relay click but that is all that happens. Can you please tell me that there is an easy and inexpensive fix. thank you
Posted by John McAnulty on
5 Related Answers
Anonymous
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
Anonymous
  • 334 Answers
SOURCE: Haier Wine Cooler motor died
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
Posted on Jan 27, 2009
Ken Bledsoe
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
Anonymous
  • 334 Answers
SOURCE: Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Posted on Aug 25, 2009
Jacques Alexandre
  • 183 Answers
SOURCE: Wine temp on Haier wine
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Posted on Dec 31, 2010
1998 chevy cavalier turn on key,dash lights flash and something under dash clicks and wont start
Either you have a ignition switch problem or there is a aftermarket alarm.When there is just a clinking this tell you there is not good contact being made.
Mar 15, 2012 | Cars & Trucks
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
My frig not cooling or freezing.(Room Temp inside) Both fans are working, Lights working, Has power, Hear clicking from rear bottom. Clicks on then off. Compressor at room temp and coils too Model...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | Refrigerators
2002 Jeep liberty headlights cut off and then back on at random times. weather makes no difference nor hot or cold. went a way for a few months and now it has started all over again. hear clicking sound...
the clicking your hearing is the relay trying to stay engaged, its heating up causing the relay to power down, which in turn you lose the lights, the heat is caused by the electrical current supplied to the replay, Not the outside temp , locate that relay and replace it, and your problem should be gone
Aug 10, 2011 | 2002 Jeep Liberty
No start condition new battery , good starter, turn key to start position light come on dash, go forward to start light go out and you hear click under dash area like relay, no power getting to starter....
no starter relay is always at the fuse relay box at the engine compartment. The relay that you hear is the relay for the accessories to turn off the power during starting position.
Feb 01, 2010 | 1999 Ford Windstar
Hear clicking sound from Passenger window, but won't roll up or down
The clicking is the relay, that means the relay is ok, if it didn't click it would be defective, you most likely have a faulty power window motor.
Oct 21, 2008 | 1994 Nissan Pathfinder
Power light turns on turns off continuously
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Jul 31, 2008 | Hitachi 43UWX10B 43" Rear Projection...
WILL NOT CONTROL TEMPERATURE
there is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Jun 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Haier BC112G Wine Cooler Logo
486 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Haier Furniture Expert? Answer questions, earn points and help others
