I already have a account for Grepolis, But when I try to login or fill out the login. All I get is we don't know this e-mail or this e-mail is already taken. I can not login to any other game. I still can login to Grepolis. Help
SOURCE: unsure how to login to planet router
To find a user manual go here.
The default login for your router you can find here.
The default address is 192.168.1.1, but you did not mention which router model you have. So go to the first link and download the manual for your specific router. All information should be in there.
SOURCE: AfterI login to pogo site, nothing happens. Ican't get the games
This issue could have a variety of causes...Please use the links enclosed here to help you fix it!
Still having problems?
Please try to work through these steps:
If you can't work through the problem in this way, please write back a comment to this thread and report the results. We'll be happy to help you further...
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: i turn on my puter it goes to the user login and then logs off
I've run into this problem too often lately. So far I haven't managed to find a decent fix for it :( I've ended up having to backup the computer's data, reinstall windows, and restore all the data.
From the times I've seen it you get to the login screen, click on your user, get the "Loading personal Settings", a quick flash of the desktop, then back to the login screen saying "saving personal settings". It would do this in both safe mode and normal mode, so I was never able to try turning off startup software or services.
Booting to the windows XP disc and running a check disc might help, but from my experience with the problem you will probably need to reinstall windows. Hopefully someone else has a better idea.
Best of luck :)
SOURCE: Login/Locked Out problems Vista Ultimate(64)
Just restart the system and then try logging in,
you can also try restarting the computer in safe mode and then check the results
