SOURCE: dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
SOURCE: GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
SOURCE: Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
SOURCE: middle wash arm doesn't turn on quiet power 1 ge dishwasher
The last two holes (the ones wich give the spin to the arm) are blocked. Remove the arm and try to unblock with a thootpick and by running water into the arm.
Good luck
Often an object falls threw the rack Therefore blocking the wash Arm from spinning.
