Question about Samsung LN-S4695D 46 in. LCD HDTV
Samsung reset codes
Power indicator flashes on tv come on gor a second and powers off is there a eay ti reset this tv?
    Top Expert:
  • Samsung Master
  • 76,407 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Aug 16, 2014
2 Related Answers
tvtek
Duke
  • 1284 Answers
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Posted on Sep 11, 2009
Sulaiman Sarumi
  • 586 Answers
SOURCE: samsung 22" lcd tv: when
If your television is blinking the power light and it is not turning on, then there seem to be a problem with the television. First try to press any button on the remote to see if it will turn on, that is to confirm if the television is not on standby.
Once that is confirmed, then it means there is a problem inside the unit, the problem is a bad
capacitor on the power supply board.
To fix this the do-it-yourself way, you will be needing these instruments: a screwdriver (40watts +), desoldering braid, soldering wire/lead, and capacitors. Before you get the capacitors for replacement, first ensure to have checked the capacitance of the capacitor in order to know the type of capacitors to get and the number of capacitors to replace.
Unplug the television for a while before starting the repair, turn to the back of the television, then you unscrew the back cover, assess the power supply board and you will find the bad caps either swollen, melted or bulged. turn to the back of the board and desolder the caps out, then fix in the new ones and solder it to the board. Make sure you take note of the negative and the positive part of the caps you are fixing in.
Reassemble the television back together and turn it on, it will power on this time.
Hope this helped.
Thank you for using FixYa
Posted on Jun 16, 2011
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Yellow blinking light . what does it mean
    A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
    OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
    LED Indications
    The front panel Status LED provides an indication of
    the set's operation and the possible cause of a malfunction.
    If an abnormal condition is indicated, perform the
    Self Diagnostics procedure.
    Self Diagnostics
    To activate, press the front panel <ACTIVITY> &<CH
    ??> buttons at the same time and hold for 5 seconds.
    The STATUS LED will then flash denoting a two digit
    code.
    • The number of flashes indicates the value of the
    MSD (tens digit) of the Error Code.
    • The flashing then pauses for approximately 1/2
    second.
    • The LED then flashes indicating the value of the
    (ones digit) of the Error Code.
    • The Error Code is repeated a total of 5 times.
    Example: If the Error Code is "23", the LED
    will flash two times, pause, and then flash three
    times.
    Table 2-2: LED Indications
    Error Codes, descriiptions and the most likely cause of
    the error are listed in Table 2-3.
    Note: The TV must be in "Shut Down." The LED
    will probably be indicating an abnormal
    condition. If the TV is switched Off, AC is
    removed, or a System Reset is performed, the
    code automatically resets to "12" No Error.
    See the Error Code Log to retrieve a history of
    errors.
    Note: Use the front panel buttons, not the remote
    control.
    Note: If there is no response, the front panel may be
    locked by a V-Chip setting. To unlock, press
    and hold <ACTIVITY> on the front panel for
    8 seconds.
    LED Indication Condition
    Off Off (standby)
    Green Power On
    Slow Blink Green Power Off with Timer Set
    Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
    Red Lamp Failure
    Yellow TV Too Hot
    Slow Blink Red TV May Require Service
    Slow Blink Yellow Lamp Door Open or No Lamp Installed
    NORMAL INDICATIONS
    ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
    Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
    Standby button flashes tv not coming on trying to locate the reset button
    The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
    Few examples are given below; some of the issues may be resolved without the need for service.
    1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
    3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
    4 blinks: - This indicates that there may be a back light or lamp power problem.
    6 blinks: - This indicates that there is some kind of audio problem with your set.
    7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
    8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
    Try the following steps to check if the issue can be resolved.
    Turn off the television.
    Unplug the television power cord from the electrical outlet.
    Let the television remain without power for 60 seconds.
    Plug the power cord back into the electrical outlet.
    If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    If the issue continues to occur, service may be required.
    Thanks for using Fixya.
    Aug 10, 2011 | Sony KP-41T65 41" Rear Projection...
    The Timer/Standby LED light is flashing on the front of the TV. Can turn on TV with sound but no picture, TV shuts off within 5 seconds.
    Aug 08, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
    Reset led blink 10 times
    Jul 16, 2011 | Sony KP-57WS520 57" Rear Projection...
    Tv shows power but no signal at all. power indicator light flashes about every 30 seconds
    The flashing light indicates a power supply problem. If the set is under warranty, exchange it.
    If your warranty is expired, take the set to a good TV repair shop and ask for an estimate.
    Feb 13, 2011 | Sanyo DP42848 LCD TV
    Tv desn't turn on,power light just flashes ten times and then stops and then again
    Error Indication Information
    Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
    (Note 3) (Note 4)
    POWER LED TEMP LED
    Note:
    1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
    2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
    change to another every 5 seconds in turn.
    3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
    or accumulated operation time of the Air Filter reaches 400 hours.
    4.LAMP OFF: The LED will flash right after the Lamp goes off.
    5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
    6.IC6001 is mounted on TV Main C.B.A.
    Clogged air filter
    more than 90%
    15)
    16)
    17)
    18)
    1)
    2)
    3)
    4)
    5)
    6)
    7)
    11)
    8)
    9)
    10)
    12)
    13)
    14)
    - flashes 5 times -
    every 5 seconds
    IC2301(pin82) detects the clogged air filter, then indicates the
    error when the air filter is clogged 90%.
    Front Fan stop or
    Lamp Fan stop
    flashes orange
    once every
    5 seconds
    IC2301(pin12) detects the Front FAN stop or Lamp
    FAN stop, then indicates the error when the Front FAN
    or Lamp FAN is stopped.
    Lamp Cover open
    Temperature Sensor
    short or open
    flashes orange
    twice every
    5 seconds
    flashes orange
    3 times every
    5 seconds
    flashes green for
    140 seconds.
    flashing red for
    60 seconds.
    light up red.
    flashes once
    every 5 seconds
    flashes once
    every 5 seconds
    flashes red for
    10 minutes
    flashes once
    every 5 seconds
    Abnormal
    Temperature
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Request for Lamp
    Replacement - - lights up
    Power Ballast Error
    (abnormal
    Lamp voltage)
    flashes 3 times
    every 5 seconds
    Power Ballast Error
    (abnormal
    temperature)
    flashes 4 times
    every 5 seconds
    Power Ballast Error
    (other causes) - -
    Request for Filter
    Cleaning -
    Abnormal Voltage
    on 16 V line of
    LCD Main C.B.A.
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Abnormal Voltage
    on 14 V line of
    LCD Main C.B.A.
    flashes 3 times
    every 5 seconds
    flashes 3 times
    every 5 seconds
    Abnormal Voltage
    on 7 V line of
    LCD Main C.B.A.
    flashes 4 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    IC2301(pin76) detects the Lamp Cover Unit condition
    (open or close), then indicates the error when the
    Lamp Cover Unit is open.
    IC6001(pin85) detects the Duct FAN stop, then
    indicates the error when the Duct FAN is stopped.
    IC2301(pin74 and 75) detects open or short of the Temperature
    Sensor (R2911) on Front Thermistor C.B.A., then indicates the
    error when Temperature Sensor is open or shorted.
    (The error is not detected for 1 minute after Lamp ON.)
    IC2301(pin74 and 75) detects the temperature attached near
    the Front FAN by the Temperature Sensor (R2911) on Front
    Thermistor C.B.A., then indicates the error when the
    temperature becomes more than 43 C (109 F).
    IC6001(pin86 and 87) detects open or short of the
    Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
    then indicates the error when Temperature Sensor is open or
    shorted.
    (The error is not detected for 4 minutes after Lamp ON.)
    the Lamp by the Temperature Sensor (R2901) on Lamp
    temperature becomes more than 60 C (140 F).
    IC2301(pin11) detects the error of LCD Power C.B.A.,
    then indicates the error when the temperature fuse
    (117 C)(243 F) in LCD Power C.B.A. is open.
    IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
    then indicates the error when an inner malfunction of LCD Power
    C.B.A. occurs, the Lamp voltage becomes more than 130V or
    less than 30V, Lamp current becomes more than 5A, or the Lamp
    is cracked.
    IC2301(pin11) detects the error of the Lamp, then indicates the
    error when the Lamp is short-circuit.
    IC2301(pin48) detects +16V line voltage on LCD Main
    C.B.A., then indicates the error when the voltage
    becomes less than +13V.
    IC2301(pin47) detects +14V line voltage on LCD Main
    becomes less than +11V.
    IC2301(pin45) detects +7V line voltage on LCD Main
    becomes less than +5.7V.
    IC2301(pin44) detects +3.3V line voltage on LCD Main
    becomes less than +2.5V.
    flashes 3 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    Abnormal Voltage
    on 3.3 V line of
    LCD Main C.B.A.
    - flashes 5 times
    every 5 seconds
    Forced cooling
    The failure of Lamp
    light up
    Temperature Sensor
    short or open
    Abnormal
    Temperature
    Duct Fan stop -
    When accumulated operation time of the the Lamp reaches
    5000 hours, OSD (replacing the Lamp) appears on the screen.
    Note: The Lamp time is stored in EEPROM (IC2305).
    When accumulated operation time of the Air Filter reaches 400
    hours, OSD (cleaning the Air Filter) appears on the screen.
    Note: The Filter time is stored in EEPROM (IC2305).
    During forced cooling, this indication is indicated.
    IC2301 (pin11) detects the failure of light up processing of
    the Lamp, then the POWER LED is changed as follows.
    1) POWER LED flashes green for 140 seconds (while turning on).
    2) POWER LED flashes red for 60 seconds (while cooling).
    3) POWER LED lights up red (standby).
    Note: If the Lamp will not light after attempting turning on the
    power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
    LCD Main C.B.A. may be defective.
    Error Symptom Problem Possible Solutio
    May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
    Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
    Here's the basic troubleshooting:
    1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
    2. Disconnect ALL devices from the TV.
    3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
    4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
    5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
    6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
    7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
    Please let me know the code you got and I'll tell where the problem lies and how to fix it.
    Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
    Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
    There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
    Oct 30, 2008 | Panasonic TH-42PD60U Television
    TV won't power up
    Generally,first step is locate open pico fuse(s) in power supply,usually feeds convergence amps. Next,replace STK devices.Then,reset alignment in servicer mode.
    Oct 02, 2007 | Mitsubishi WS-55807 TV
    Samsung LN-S4695D 46 in. LCD HDTV Logo
    526 people viewed this question
    Muntejaya Ginting
    Muntejaya Ginting
    Todd Hill
    Todd Hill
