Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
How to change belt on shark navigator vacume - Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
2 Related Answers
Anonymous
  • 134 Answers
SOURCE: we broke our infinity shark vacume belt
You need to go here and order your belts
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
Posted on Feb 14, 2009
jamielyn77
jamielyn77
SOURCE: shark navigator. How do you get to the belt?
in addition to the obvious screws, and two under the main coaster wheels, there are 2 hidden under the 2 mini wheels up front. pop them out and remove.
this voids any warenty i think
Posted on Jun 03, 2012
My shark navigator won't pick up model # NV 26 the brush won't roll
Hello, this is Ava with Think Crucial.
If your the brushroll is not moving there could be several problems
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for troubleshooting solutions.
Secondly, your vacuum may be in need of new parts. By changing either the brush roll or belts, you should be able to increase the quality of the suction.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Nov 09, 2016 | Shark Vacuums
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
What I need is a replacement part for my shark vacum, it is the hose part and I believe still under warrenty for the next 9 years. Do you think you could send me the broken part ?......
Shark does not make replacement parts. Throw it away, it's a true disposable machine. If you want a second opinion, call any vacuum repair shop, they'll tell you the same thing.
Jul 16, 2014 | Euro-Pro NV22 Shark Navigator Bagless...
Shark Navigator blowing front filter out of the vacum cleaner.
Dear sir, This is the most likely cause of this problem: Be sure that the top tabs and the bottom lock clip are not damaged. (red arrows on photos of my own unit) These hold the filter in place. If damaged you may try several layers of super glue, or oder replacement part from shark.com parts for this model. good luck.
May 19, 2014 | Shark Navigator Bagless Upright Vacuum
How to replace belt on shark navigator
Call Shark cust. service. They should send you a new head
Mar 30, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Shark instruction manual
How do I change belt on shark navigator NV35627?
Jan 04, 2014 | Shark Vacuums
How do I change the belt on a vacuum cleaner
You don't. Call cust. service, they sound send a new head.
Mar 21, 2012 | Shark Helmet NV22L Shark Navigator Upright...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
367 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Muntejaya Ginting
Muntejaya Ginting
Richard Schabler
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
