Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 Gas Stove
We just moved, everything worked just fine before, it is hooked up to natural gas, the ignitor clicks but will not light burners any suggestions.
Posted by dcarl1030 on
  • Anonymous Sep 07, 2008
    I have ge xl44 gas range with self clean oven. Two days ago I went to turn on the oven and after 20 min. the light on the area with the timer would not go off when it reaches temp. I open the door and the oven was barely warm. I then went to see if any of the four burners ould turn on (they only clicked and did not start. Any ideas? randy
Anonymous
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Posted on Mar 03, 2009
Anonymous
This Randy again. I checked out the top of the stove as you suggested and found every thing to be ok. Where might the pilot light be located on this ge xl44? this unit is about 13 to14 years old.
Thanks for your help
Randy
Posted on Sep 18, 2008
Gerald Griffin
  • 248 Answers
Check to be sure burners are on properly and that the burner caps are on squarely. Make sure they are in the correct locations.
Posted on Nov 09, 2007
btdor
Our ge xl44 oven is making our pans have a black residue on them. We have adjusted the flame, but we have to go too low to make the black residue disapppear, and then our cooking time is nearly doubled and/or not hot enough...Anyone have any suggestions? Thx
Posted on Jun 04, 2008
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
XL44 GE oven not working. Bottom burner not getting gas.
You probably have a bad ignitor. If the ignitor does not draw at least 3.5 amps the gas valve will not open. This is a safety feature.
Nov 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
Ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
3,118 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
