Sorry no answer but can confirm I have the same issue with a DMR BS750 (same machine smaller hard drive ) connected to a Panasonic TX-L37G10B. DMR no BBC1 but BBC 1 ok on the TV have you had any luck with an answer? [email protected]
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
selact menu on remot cantrol and see on the screen tunig menu in chenal edit to selact .
frist selact ch for edit and set your chennal no 1 /2 or 3......after the selact no prees OK key to fix your fureat ch. in your selacting no.
EXP:
ch . pisesion 36 [BBC1]
edit ch No 1
then prees OK key and see your BBC! is ch no 1 on your remot.
If you have all 3 tv's in the one house and on the one antenna then it sounds like you have been subject to either a lightning strike or a large static discharge onto your antenna. What this means is that the tuner packs in the back of the tv's has been damaged and will need to be replaced. However as you have said in your question they do work using an av input. This will be your cheapest option to get them working again. Buy cheap vcr's for them and connect via av cables, as the tuner modules are expensive to buy and even more so to have fitted.
