Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
It worked fine until we had to add VCR to get Dish satalite
SOURCE: GE 48" rear projection tv
Might be the convergence power supply, if you dont know how to work on tvs, I would suggest getting a service man.
Posted on Jul 06, 2007
SOURCE: GE D52GW12 52 in. Rear Projection HDTV-Ready
hi
i agree with you about the fire hazard and i had many feedbacks about this tv, mostly conscious about fire hazard too.
i would suggest that in light of owning a high-def tv, it would be significantly appropriate to place this in a room with airconditioning as to diminish the heat this hdtv produces.
about the issue of the hdtv turning off, if you suspect the transformer and other parts to be the reason for the tv to malfunction, why not bring it to a certified service center which handles GE hdtv. i would say that it may be a pain but as to think of the outcome, it may be worth it.
hope this helps.
Posted on Jan 21, 2008
SOURCE: Rear Projection
They are under the picture setting in the adjustment menu
Posted on May 08, 2008
SOURCE: projection tv
I wonder if yu are still dealing with this problem so I can help you
Posted on Aug 24, 2008
SOURCE: GE Rear Projection TV set with "3D" colors
This is a common problem that was NOT caused by watching the 3D movie! Bad solder connections on the high voltage transformer have caused a solder in fuse to blow. The transformer will have to be resoldered and the fuse replaced.
Posted on Jul 30, 2009
