Question about Kenwood KDC-HD548U Car CD/MP3 Player - 200 W RMS - iPod/iPhone Compatible -
I need the wring diagram for a Kenwood KDC-HD548U
Im hooking it up to a 96 oldsmobile Aurora
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
Posted on Jun 21, 2008
Anonymous
  • 132 Answers
SOURCE: kenwood kdc-x592
They dont work with classic ipod for direct ipod connection, also try updateing the firmware in your ipod this is a common problem, deck looks sweet tho eh?
Posted on Jul 25, 2008
Anonymous
SOURCE: 2000 OLDSMOBILE AURORA SERPENTINE BELT DIAGRAM
Look on page 6-70 of your owners manual. It is listed under Engine Accessories Belt
Posted on Dec 07, 2008
Anonymous
  • 22 Answers
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
Posted on Mar 10, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I NEED A DIAGRAM OF THE FUSE BOX FOR A 1995 AURORA
go to link and follow links to free GM web site for a PDF of your owners manual.
http://www.edmunds.com/ownership/howto/articles/120189/article.html
Posted on Apr 19, 2009
Looking for emergency fuel shut off for 96 Olds Aurora
Only Ford products have inertia switches.
The relay is powered by a fuse and controlled by the computer.
Jul 28, 2012 | 1996 Oldsmobile Aurora
Have a 96 aurora, won't shift into 4th gear? all
have you tried flushing ****** and changing ****** filter
Mar 04, 2012 | 1996 Oldsmobile Aurora
I want to know where the temperature coolant sensor is on a 96 oldsmobile aurora. If someone could send my a diagram or picture of where it is located.
I know there is one under the plastic intake manifold. You will have to remove it to get to the sensor though. I don't know if this one is for temp. gauge or fans or both?
Jul 08, 2011 | 1997 Oldsmobile Aurora
I have a 1996 oldsmobile aurora and my problem is one of my gas lines has a small drip, so how do i change it out myself
have a 1996 Aurora. under the hood the plastic gas lines 2 are hooked up to the carb but one is broke off,does this have to be hooked up?
Aug 03, 2010 | 1996 Oldsmobile Aurora
Looking for a serpentine belt diagram for a 96 Olds Aurora witha 4.0. The diagram is gone from under the hood
CLICK on the following LINK.
It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1996/make/oldsmobile/model/aurora/1996_oldsmobile_aurora_drive_belt_routing_diagram.htm
Jan 17, 2010 | 1996 Oldsmobile Aurora
Hi how do you replace an alternator for a oldsmobile aurora
Oh wow. I am gonna assume this is the 3.5l v6 engine. If this is the case, then the alternator is under the engine just above the right side drive axle. If this is that engine , then it must be removed from the bottom of the car. The engine cradle must be lowered to access it.
Aug 17, 2009 | 1996 Oldsmobile Aurora
My blower wont kick on in my 96 Aurora
you can test this motor with a multi meter but, im sure its dead. i would also, check the fuse box to see if the fuse is OK.
Mar 13, 2009 | 1996 Oldsmobile Aurora
I have a bad trans in a 96 olds aroura
Unfortunate all that is available for transmissions for the 1995 and 1996 aurora are the 1995 and 1996 year! The transmissions fron any other year are not compatible or interchangable on the 95-96 years!
Jan 15, 2009 | 1996 Oldsmobile Aurora
Heater blower motor wiring diagram
replace the bolwer motor relay mounted on the fire wall the relay is stuck in the on poition.
Dec 07, 2008 | 1996 Oldsmobile Aurora
Kenwood KDC-HD548U Car CD/MP3 Player - 200 W RMS - iPod/iPhone Compatible - Logo
127 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Todd Hill
Todd Hill
Michael Thomas
Michael Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
