Question about LGDVT418 System
LGDVT418 Red light stays on, even after unplugged for short time, interrmitant
Red light stays on, Sometimes 1 of 50 Green light comes on and it works fine. Unplug Red light still stays on for a while
Posted by Danny on
Thomas Beaver
  • LG Master
  • 2,119 Answers
Doesn't sound good. Here is a link to the owners manual.
http://www.manualslib.com/manual/93213/Lg-Lgdvt418.html#manual
LG DVT418 Owner Manual
Posted on Aug 15, 2014
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Amp is going out.
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
May 10, 2009 | Car Audio & Video
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
LGDVT418 System Logo
Top LG Audio Players & Recorders Experts
tina gallow
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
