The presser foot won't come down
SOURCE: service manual for pfaff 7570
www.sewusa.com is a good place to look if your machine is not listed email them and they will try to help. Also look at their "repair or threading page".
SOURCE: 7570 Presser foot leaver..Slow to dropp down
Good morning,
If it's been a while (more than a year) since you've had your 7570 serviced by an authorized Pfaff tech, it's likely that it's just gotten gummed up and needs some attention and adjusting.
It's definitely fixable, but not something that you'll likely be able to do yourself - some of those parts are just not easy to get to and the lubricants needed aren't directly available.
Hope this helps,
Kim & Linnette
www.sewingexpressions.com
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
