I have windows 7 in my laptop and i want to print some documents from my laptop using Canon Photocopier IR2016J using USB Connection Between Photocopier and Laptop. But when i insert USB cable in laptop then nothing happening in laptop screen. No detection No Installing driver of Printer USB. What is problem in USB connection ??
SOURCE: Laptop does not detect new Canon printer.
somthing you can also do if you find that your usb ports are damaged and you have p.i.m.c.a ports you can get a pimca card with usb support
SOURCE: my laptop does not detect my hp photosmart 8050
First, remove and reinstall the printer driver and disconnect / reconnect cable to see if your problem is resolved.
Try switching to a different USB port on your laptop. Also, the cable could be faulty.
Test the printer on another PC or laptop to see if the printer is present. If present, your laptop is problematic. If not present, the cable or printer is faulty. Hope this helps.
SOURCE: usb to not detect ir2016j canon xerox machine
Usb to not detect ir2016j canon xerox machine.
SOURCE: i just newly change my
Hi ,
All you need is a Windows 7 compatible driver . Download and install it from here . Select first the correct OS :
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150#sf
Best regards ,
fanaudi .
SOURCE: I have a canon ir2016
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
