Some connection has not been firmly made, or the little safety switch at the back of the machine was accidentally pushed.
1) Check the back plug and make sure it is inserted FIRMLY. Does the machine work now?
2) If not, check the little switch in the back with the 0/- markings. Make sure it is depressed to allow power to the machine (try it after checking the plug.)
3) Check the fuse.
4) Unplug the machine and go back in to make sure the UV bulb is firmly inserted. It needs to be turned so that it "clicks," or "seats" correctly at both ends.
If none of these steps work, go through your Owners Manual step by step, checking all connections and wires. Make sure nothing is visibly loose, corroded, or broken. An owners manual is available at
http://www.vollara.com or call Vollara customer service at 1-800-989-2299
