Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
How long after plugging in fridge should compressor start ?
Ty Roshdy
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
It should start up within a couple minutes. the electronic control board controls the compressor as well as all the other functions of the refrigerator. If the refrigerator is cold when you plug it in then it may not start right away but opening the doors for a few minutes should get it to start up. If it doesn't come on after a few minutes the control board may have issues.
Posted on Aug 17, 2014
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
May 04, 2018 | Samsung Refrigerators
How can you tell if the fan needs to be replaced?
Hi McRobbie
The devil in the details here is where the clicking is coming from, and which fan we're talking about. There can be fans circulating air in the freezer or fridge, or blowing a certain amount of freezer air into the fridge (the latter is more or less how the fridge side is usually cooled). There is also a fan that will blow on the compressor to keep it from overheating. What you may need to do is, with the fridge away from the wall and plugged in, come near to the compressor (a black metal object that looks like this
image refrigerator compressor Google Search The clicking can be the system trying to start the compressor. There is usually a bit of gear tied into the compressor that lets it build some juice in a capacitor for the startup to get moving. If the compressor isn't actually starting, then likely as not the fan won't start either, making it a symptom rather than a problem.
Is the fridge cooling now? If so, then the compressor is able to start. If not, the clicking is probably failed compressor starts. Otherwise, there will be the fan right next to it (see about halfway down the page here
Appliance411 FAQ Frost Free Refrigerator Not Cooling Properly
The latter page has a good checklist of other diagnostic possibilities.
hope this helps!
D
Dec 04, 2015 | Refrigerators
Whirlpool fridge WB5534XP-Aa problems fridge warm up and cannot hear the compressor starting
That is still enough time for oil to go into the evaporator and cause problems for the compressor starting. Keep it upright and don't leave the power plugged in while you are away. Plug it in and try for about five minutes at a time. If it does not start then come back later and try again. Eventually it will start so when it does I believe you will be good to go! Let me know if you continue to have problems or if this works for you, Thanks, John Tripp Appliance 911 if need
Contact Me Here
Feb 24, 2014 | Refrigerators
Hi there, I have a Samsung RS21DCNS F/F. and have just moved house and connected it all back up. The LED display lights up, but the fridge and freezers won't cool and there's no motor or fan...
Was the fridge laying down? How long? Rule is if a fridge is laying down for an hour leave standing for a minium of an hour WITHOUT PLUGGED IN. ^hours laying equals 6 hrs standing. I tell everyone give it 24hrs of standing to eliminate problems. If you plugged it in without enough time for the oil in the compressor to return back to the compressor you may have fried your compressor. Now if you did leave it long enough and the oil in the compressor got back in compressor before plugging in. It could be in your defrost timer or your start relay. Does the fan in freezer come on? Push the switch to make the fridge think door is shut. If fan does not run it sounds like the defrost timer. If fan does run the check the start relay on compressor. Does the compressor turn on? Do you hear a clicking sound coming from copressor? If you hear a clicking noise than its your start relay trying to come on. Replace start relay and overload. The model number you gave me is not valid so get the full model number and check thru Searspartsdirect.com
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung Refrigerators
Light on in fridge but not working
I would replace the start relay located on the side of the compressor. If you feel the
compressor and it is not warm, then it is not running.
Under the plastic cover on the side of the compressor is a small relay with 3 pins that
plugs onto the side of the compressor. If a replacement is not readily available
they sell a "universal" start kit that simply plugs onto the terminals of the compressor
It runs around 8 dollars and has good instructions. Remember to unplug the fridge
before doing any work. The model and serial number is inside the fridge on the
left side for most models. The part should be available at any appliance parts store.
Hope this is helpful.
Jul 18, 2011 | Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Our side by side has lost its cool. The fridge section is luke warm while the freezer section is not working. We removed the started device that's plugged into the compressor, debris fell out, we...
Shut off the fridge for few hours and check the starter in the compressor which is having a fault. If your compressor is not running well then you will have to see if the starter is heating. If so replace the starter so that the compressor gets better current. You will need help to check the pressure of the gas and the pumping pressure of the compressor. The starter will click and start immediately to run the compressor. If the fridge does not cool the fault will be with the gas pressure or compressor. If not check your defrosting circuit, the timer and the thermostat. SO check this out. Good day
Aug 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My copressor won't start. relay works fine in
HAVE YOU TRY A 3-N-1 COMPRESSOR BOOSTER|? YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE THEM. TELL THEM THE SIZE OF YOUR FRIDGE AND COMPRESSOR AND THEY SHOULD BE ABLE GIVE YOU THE RIGHT ONE. FOLLOW THE INSTRUCTIONS ON THE 3-N-1 AND CONNECT TO THE COMPRESSORS. BUT CONNECT THE TWO BLACK WIRES TO A EXTERNAL POWER(GET AN EXTENSION CORD AND CUT IT, WIRE NUT THE TWO WIRES TOGETHER). PLUG IT IN, IF THE COMPRESSOR KICKS OFF, YOU HAVE A BAD COMPRESSOR. IF IT RUNS WITHOUT KICKING OFF, THAT MEANS YOU ARE NOT GETTING POWER TO THE OVERLOAD RELAY TO TURN KICK ON COMPRESSOR. CHECK YOUR TEMP CONTROL INSIDE FRIDGE, AND THE DEFROST TIMER(MIGHT BE STUCK IN DEFROST)
Jan 24, 2010 | Amana Freezers
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
107 people viewed this question
Top Refrigerators Experts
Mike McBirney
Level 1 Expert
gbob59
Ron Rak
Ron Rak
