These are lean fuel codes for both cylinder banks, the most common cause is a vacuum leak at an engine vacuum hose ports or the brake booster is leaking, check all the vacuum hoses, replace any that are deteriorated
Mate I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
TRY THIS. REMOVE THE INTAKE ON THE RIGHT SIDE OF THE CAR .THE EGR VALVE CLOGS UP WITH CARBON SOMETIMES CHOKING IT OFF COMPLETELY. IT WILL BE HARD TO START WHEN THIS IS CLOGGED. CHUNK OUT THE CARBON WHERE THE BUILD UP IS. REPLACE WITH A NEW EGR.
I had the same problem on a Rover. There was a leak in inlet manifold that was caussing the problem.
To verify, spray some sealant to temporarily seal the inlet manifold .and the eratic idling should disappear for some time.
If it does, you know there is leak in inlet manifold which you can take of and refit with a new gasket.
