I have a new kwc domo faucet I just installed and when I opened the water supply lines it was fine but when I pulled the handle up on the faucet water poured out from under the sink. No water was coming out of the faucet just under the sink.
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
SOURCE: leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
SOURCE: Sticking of KWC DOMO model faucet.
I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
