How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
